1970 Massey
Steve Brussell
10-15-2006 17:10:08
Well, I got a look at it today. It is a 1970? Model 300 with a 4 cylinder Perkins. Appears most hydraulic lines burned along with the harnesses , gauges, seat, steering wheel, and right tire is gone. Left rear tire is brand new and fronts are good. Bucket cylibers do not appear damaged. He wants $500. Any thoughts? Thanks, Steve
smokey2
10-15-2006 22:45:38
 Re: 1970 Massey in reply to Steve Brussell, 10-15-2006 17:10:08
Check carefully for water. If it was hit when hot with water it will have found its way into all sorts of places. ie gear box or motor. Has it been stored in a dry place as condensation/rain could easily penetrate into those places as well.
I am rebuilding a MF135 that was burnt 10 years ago. It is a good experience providing you have a use for the machine and do not mind searching for parts and have planty of time. Most seals and bearings I have had to replace are also gone on the MF135 I purchased as a replacement as these tractors are 35 years old.
135 Fan
10-15-2006 18:39:58
300 is probably the model of the loader making it an industrial tractor. Are you sure about the year? It could be an MF 50 or if older a 302 with manual shuttle or a 304 with instant reverse. If all the hydraulics have to be rebuilt or replaced it could get expensive. Does the engine run or at least turn over? $500 isn't too much if you can at least salvage some parts. Getting it running again would take lots and lots of time and probably money. It would need to have all new seals put in, a new wiring harness, gauges etc.. I think I'd look for something that didn't need almost everything on it fixed. Just my opinion though. Dave
