Massey Ferguson 50 multi power diesel hydrolic pu
Kevin Estey
10-14-2006 04:31:07
I am trying to remove the hydrolic pump in a massey ferguson 50 diesel .my repair manual states the pump should lift out after i backed off the pto shaft.Removed the collapsable drive shaft and backed off the to pins on the side it is loose but there is not enough room to lift it right out .Do i have to take the pinion geat out ot the gears on the front of the pump off. thanks Kevin
Big Dean
10-14-2006 08:14:43
 Re: Massey Ferguson 50 multi power diesel hydroli in reply to Kevin Estey, 10-14-2006 04:31:07
Kevin depending on if your MF50 still has the original multipower pump you may be able to unbolt the multipower pump from the bracket that sets above the three point pump they will sometimes lift out the top some the bracket for the multipower pump will not come through the top opening if not you have to split the tractor between the transmission and rear center housing. If it has been changed to the newer style that has the two plates with a gear train in them the multipower pump bolts to then you will have to split it to get the pumps oit.
