Lift
john white
08-13-2000 21:48:49
Lift won't go down Massey 135 if i turn it off it will leak down in a few hours but when i crank it back up the lift just go's back up
Richard
08-26-2001 20:26:11
 Re: lift in reply to john white , 08-13-2000 21:48:49
My MF 65 is doing the same thing. If you find out what is causing your problem mine might be the same.
Jack in NB
08-16-2000 03:18:19
John -
Sounds like your pump is in full operation all the time.
This likely means there's something adrift in the linkage between the quadrant levers and the pump; the pump control lever is being held in the operating position.
Shop manual is the first step, then remove the cover with the transmission dipstick to see what's wrong.
