Removing temperature probe?
Jrry
10-12-2006 06:33:39
I have a MF 65 Diesel that I need to replace the temperature guage. The probe going into the block on the old one is rounded and I cannot get a good wrench on it. There is also very limited room to get to it without removing the fuel tank. My question is there much danger of messing up the block by using a drill to remove the probe as long as I'm cautious.
Gerald J.
10-12-2006 08:43:28
 Re: Removing temperature probe? in reply to Jrry, 10-12-2006 06:33:39
Kroil it, maybe PB Blaster. There's lots of corrosion because of dissimilar metals.
Gerald J.
souNdguy
10-12-2006 06:38:22
Small pipe wrench?
Soundguy
Jrry
10-12-2006 07:00:28
 Re: Removing temperature probe? in reply to souNdguy, 10-12-2006 06:38:22
SouNdguy, I tried that but just could not get enough grip. Someone (not me this time)has just about distroyed the outer part of the probe. If I removed the fuel tank I may be able to get to it enough to get a grip with the pipe wrench but I was not wanting to remove the tank if possiable. thanks
souNdguy
10-12-2006 11:31:02
 Re: Removing temperature probe? in reply to Jrry, 10-12-2006 07:00:28
Stud puller?
Soundguy
Jrry
10-12-2006 11:39:30
 Re: Removing temperature probe? in reply to souNdguy, 10-12-2006 11:31:02
I don't have one of those but it may be worth the investment to give it a try. thanks
david from mo
10-12-2006 18:13:49
 Re: Removing temperature probe? in reply to Jrry, 10-12-2006 11:39:30
I would try cutting off tube and driving a six point socket on the nut. Sometimes a metric socket will hold better.
