Loader bracket
Luke Dunbar
10-10-2006 15:10:39
Is there anybody out there with experience of attatching a loader belly bracket to a Massey 35?
I have a MF 38 loader and am confused about how to connect its belly bracket to the belly of the tractor. I have searched high and low for information regarding this but in vain.
On the underside of the tractor just in front of the steering wheel I can see 4 bolts that hold a plate and gasket in place.This is the only obvious place that the bracket attatches.Is this correct?....and if so..... if the plate is on the underside of the transmission and has a gasket surely i am going to get covered in oil when i remove it.
Of course it may be that this is not the correct place or way to mount this bracket. I would welcome any experienced advice.
Luke Dunbar
10-24-2006 17:54:57
 Re: Loader bracket in reply to Luke Dunbar, 10-10-2006 15:10:39
Finally got round to mounting the bracket today and all is well. No huge surge of oil from the clutch housing..... ....phew!!!.
Geoff Gane
10-11-2006 06:30:32
Luke all the information you have been given by others is spot on...remove the inspection plate from underneath and in the 4 exposed holes fit 4 studs as are used to hold on the swinging drawbar base plate...these are much better then the set bolts which some people use...screw them in TIGHT..tight studs don't break where as slack ones do as is the case if you fit set bolts...I have fitted many loaders and this the path I have used for many years....a tip I picked up from one of the MF service instructors...Happy loader fitting..Best regards...Geoff
135 Fan
10-10-2006 17:44:20
Easy-on loaders used that area for mounting. Check the hole pattern on the bracket. I'm not sure if there is oil there or not.
135 Fan
10-10-2006 21:47:55
 Re: Loader bracket in reply to 135 Fan, 10-10-2006 17:44:20
I was just thinking that that plate is under the clutch so it shouldn't have oil. At leasst I think it's under the clutch. Loosen a bolt and see if oil comes out. It should be dry if it's under the clutch.
Luke Dunbar
10-10-2006 19:28:34
Yup this is the spot where the brakets match up. I'll give it a go then tomorrow if possible
135 Fan
11-04-2006 10:07:50
 Re: MF 165 - How to clean the fuel sediment bowl in reply to Don-Wi, 11-03-2006 23:26:35
Bad memory? LOL
GaryF
10-11-2006 04:56:43
 Re: Loader bracket in reply to Luke Dunbar, 10-10-2006 19:28:34
Luke...Do you have the rear mounting brackets that fit under the axle and into the ends of the loader frame?
I have the parts manual from 1969
Gary
Luke Dunbar
10-11-2006 08:42:19
 Re: Loader bracket in reply to GaryF, 10-11-2006 04:56:43
..... ...I just bought a parts manual off ebay which should be here at the end of the week. Hopefully that will also help.
Luke Dunbar
10-11-2006 08:24:45
I have the rear brackets. It has to be said that they have seen some action and are a little bent. I imagine it is quite hard to find replacements so i will have to do at the moment.
135 Fan
10-11-2006 09:40:08
 Re: Loader bracket in reply to Luke Dunbar, 10-11-2006 08:24:45
Good luck with your mounting. I wouldn't buy any more hoses from Napa though. Hydraulic hose shops should be way cheaper.
Luke Dunbar
10-11-2006 08:39:35
Thankyou for everyone's help on this one. I did not get around to mounting the bracket today but i did test the hydraulics. I had 2 new hoses made up at the local Napa garage..... ....$70 for 2x4' hoses ouch!. I cleaned the Control Valve which had 40 years worth of grime on it.....then fitted it.... Connected it with the cylinders and up they went plus the 3 point seems to operate aswell which is good news.
