TO-35 won't shut off
David Dawson
10-09-2006 20:15:43
Just repaired some wiring on my '59 TO-35, now when I take the key to 'off' the tachometer goes full scale and the engine doesn't shutdown, if I remove the plug from the alternator then it shuts down as it should, ie tack goes to '0'and engine stops. It appears as the excitation lead to the alternator is backfeeding and not allowing the key to stop engine. Any ideas????? ??? Thanks for your help..... ...
David Dawson
10-10-2006 19:04:26
 Re: TO-35 won't shut off in reply to David Dawson, 10-09-2006 20:15:43
Done and FIXED>>>>>>>>>>>>>>>>>>>>>>>>> Thanks to all. Now if I could get that rear oil seal in my old ford 4000 diesel fixed. Thanks again, David
peltsi
10-10-2006 09:17:30
add a diode to the wire going to the excitation lead. it acts as a one way valve and will stop the backfeeding problem.
Dean
10-10-2006 06:15:56
David:
This is a common mistake to make when converting to a 12V alternator charging system. You must wire a diode in series with the alternator to prevent this.
There has been a lot of discussion about this in the past. Search the archives here and on the Ford N board for instructions and drawings about how to do this.
Dean
