Found the leak in hydraulics
John Sugden
10-09-2006 19:12:35
I think I did anyway, I will get new O rings tomorrow and find out for sure. I thought the leak was coming from where the water pump bolts to the engine, but when I took it apart there is no water pump. it is the hydraulic pump mounted behind the fan blade. When I pulled the resevoir off of the pump the O rings are flat, I am assuming this is the problem. Also, if anyone can tell me what type of hydraulic fluid to use that would be great, I put regular hydraulic fluid in but want to make sure it isn"t supposed to have automatic trans fluid or something else in there. Just looking for advice on this little pony as the last time I drove one of these I was 8 years old and didn"t have to do any maint. Thanks guys,
Vacherie
10-10-2006 17:43:32
 Re: Found the leak in hydraulics in reply to John Sugden, 10-09-2006 19:12:35
The service manual for my Pony calls for 1-1/4 quarts of SAE 10 engine oil. When refilling the reservoir fill up to the baffle then operate the engine and lift. Refill to the baffle again. Good luck on the repairs. By the way torque the lines to the control valve to 7 to 9 pounds/feet only.
Jerry/MT
10-09-2006 20:49:43
It would be nice to know what model tractor you have!
John Sugden
10-10-2006 19:42:33
 Re: Found the leak in hydraulics in reply to Jerry/MT, 10-09-2006 20:49:43
Sorry, It is a 1957 Massey Harris Pony.
