fe 35 venting oil blue smoke
noo
10-09-2006 15:42:35
Just got a FE35 with the perkins diesel. Starts alright runs good has good power oil pressure in the green but venting out of the crankcase vent and out of a 3/8 inch hole beside the generator mount on the front of the motor. Any ideas would be helpful.
Jerry/MT
10-10-2006 14:27:51
 Re: fe 35 venting oil blue smoke in reply to noo, 10-09-2006 15:42:35
Excessive smoke out of the crankcase vent usually means excessive blowby which means your compression rings on the pistons are worn. With the blue smoke your oil control ring isn't controling the oil so it time for a compression check and a possible ring job.
noo
10-10-2006 17:23:11
 Re: fe 35 venting oil blue smoke in reply to Jerry/MT, 10-10-2006 14:27:51
Thanks for the reply Jerry, unfortunately I don't have a compression tester high enough for a diesel but I kind of suspected worn rings or a hole in the piston by the crank pressure. I just couldn't figure out why I'm not getting any blue smoke in my exhaust and why there is pressure and smoke venting out of the hole in the timing cover.
