Hi Independent PTO is a good feature easyer to operate you can put it on and off on the go. But.... I bough a MF-135 with independant PTO few years ago we tried the PTO on a hay baler and it seemed to work fine. When I hooked it to the rotovator it slipped and even dont turn the rotovator when engaged in the soil. Lucky me....The PTO pump input oil filter was clogged and damaged. I changed the filter and rear end oil and voila...the PTO no longer slips it can kill the engine if rotovator is too deep in the soil. If the IPTO clutch pack is defective it cost over $1000 just in parts to rebuilt it and I dont know if parts still available. If I have to buy an used MF I wd avoid buy one with multi-power and/or IPTO there are the weakest component on these tractors..otherwise MF are very good utility long lasting trouble free tractors. For the IPTO brake it is not intended to stop a turning implement it is for keep the shaft stopped when you hook up the implement shaft. When operated we must idle the engine then disengage the IPTO.. this way the brake will not try to stop the implement inertia...this brake pad it mini tiny fragile and weak. Who knows the previous owner may never used the IPTO and may be almost new ??? Just my 2� comment Joe Ferguson
