whats a 1973 mf-165 diesel worth
ric1
10-07-2006 09:18:59
i found a 165 diesel with multi power less than 3000hrs i owner its a 1973 it also comes with a loader the fellow died and his wife is asking $6500.00 for it i thought was a little high what you guys think
Aaron Ford
10-07-2006 21:48:01
 Re: whats a 1973 mf-165 diesel worth in reply to ric1, 10-07-2006 09:18:59
C'mon, where is it?
Aaron
135 fan
10-07-2006 13:21:28
If you buy it and don't like it, you could auction it off on here and probably make a chunk of money in process. New loaders alone cost almost as much [$4000 and up for a good one]. Go fast before the line up behind you passes you. Of course everything depends on condition but this one sounds like a rare find. Good luck
MF Poor
10-07-2006 13:02:21
You don't want it. And just to prevent you from being tempted, let me know where it's at and I'll buy it. I'll do that for you. I'm that nice of a guy!
If the Multi-Power is in working order, the hours you quoted are even close, and it's any kind of decent loader, that's a good buy. I've looked at a few junker 165's lately with price tags higher than that. (I'm shopping for just exactly what you've found)
Around here, a GOOD late production 165 diesel will bring $5500(+) in a New York minute. A GOOD loader will add $2000(+). Buying it as a package deal makes it all the better.
TomTX
10-07-2006 12:13:35
If you think $6500 is too high, tell me where it is. The loader, if in good shape and a good brand like MF fitted well, adds at least $3000 to the tractor. Does it have rear remote hydraulic fitting? Is the loader a qquick tach? If in good shape, it will make a nice little tractor, and very handy with the FEL. Tom
DavidP, South Wales
10-07-2006 11:02:51
Hi,
Not sure how US prices run but if that tractor was for sale in the UK it would probably make around �3500, 4 on a good day possibly. I don't have an exchange rate to hand but I think that the $6500 is pretty close. Some points to check if you have not already done so;
If it has done a lot of loader work remove the front grill door and check the steering linkage inside, ball joints, KP bearings etc for wear.
Have someone rock the steering back and forth and look for any play as above but particularly in the main vertical shaft that goes through the casting. Whilst not generally expensive to repair- it all adds up.
Check also the clutch pedal movement. If it is a dual clutch tractor check that it has clearly defined first and second stages and that the PTO stops on its own when engaged and the clutch pressed. If it is an Independant PTO model, again check that the PTO stops when the tractor starts after a few seconds when dis-engaged. A look at the condition of the air filter is usually an indicaton of the level of maintenance it has received. Cleanish filter.....someone cares.
Hope this is of help.
DavidP
Roy in UK
10-07-2006 23:05:40
 Re: whats a 1973 mf-165 diesel worth in reply to DavidP, South Wales, 10-07-2006 11:02:51
I sounds a reasonable price.Yes David �3500 was very close.�3,473.60 is the figure for today, I use xe.com
DavidP, South Wales
10-08-2006 04:57:18
 Re: whats a 1973 mf-165 diesel worth in reply to Roy in UK, 10-07-2006 23:05:40
Not a bad guess then!
DavidP
135 fan
10-07-2006 09:45:28
It's a steal if everything works! A new replacement is probably at least $25000 and wouldn't be much better. 165's aren't as popular as 135's but are still highly sought after tractors.
