MF135 transmission seal needed/help
farrviewsouth
10-06-2006 06:55:01
My MF 135 with a multi-power transmission has been a great tractor over the years. Now it is time to replace the transmission input shaft seal and Massey has discontinued the part. Local bearing houses cannot help. It measures 1.936 outside/ 1.635 inside, with a width of .25. Can anyone assist in either a source or solution??
Thanks
farrviewsouth
10-10-2006 06:52:27
 Re: MF135 transmission seal needed/help in reply to farrviewsouth, 10-06-2006 06:55:01
Have been offline for a few days. Thank both of you for your help and I will recontact dealer with your information and also try NAPA.
I will let you know how I make out
Bruce
Big Dean
10-07-2006 10:14:06
I just resealed one of those in my shop less than 2 months ago the 2 rubber lip seals for both shafts and all of the steeling rings were still avalaible at that time also you can get then from some of the after market places. If I can be of further help email me
mn.Chuck
10-06-2006 07:29:14
Confirm with your dealer that it is p/n 1860867m3
(suffix could vary i.e. m5. Then ask him to use his agco locator-most don't offer to do so. Or go
to your local NAPA with that part no. Masseys
dimensions book varies a couple thousands from the
ones you had but we are talking about the seal
inside of a hollow shaft in the multi-power? Many
of these tractors were updated over the years with
diff shafts and other parts and now have different
seals. A depot in Chilton,Wi has had but is now
out. Chuck
