Massey Ferguson 97 Oil Leak
Rimshot
10-04-2006 19:51:19
It appears the rear main is leaking oil. Can this be repaired by removing the pan and putting a new seal in --- or will it be more complicated? Thanks
JJL
10-05-2006 18:01:20
 Re: Massey Ferguson 97 Oil Leak in reply to Rimshot, 10-04-2006 19:51:19
You may want to check the MM forum. Your 97 is the same as a MM 706.
john d g
10-05-2006 09:39:08
its a job but if ure mechanical u can do it----check with Big Dean on here---he has a cd that will help u ----- tractor will have to be split---clutch assy removed----if its oil soaked have to be replaced---also a good time to replace trans seals while u have it apart----guess what--all this for a $9 part---thats what the seal cost me good luck-----john
