MF135 lift pump RR
rktown
10-04-2006 09:10:26
okay, I give up. How do you get the fuel lines out of the pump housing? I've got the compression nuts completely pulled back, but the lines just wobble in the pump and will not pull out. AD152 Perkins diesel engine.
Big Dean
10-04-2006 14:56:26
 Re: MF135 lift pump RR in reply to rktown, 10-04-2006 09:10:26
The rubber seals are holding the lines in I always used a ice pick to pick them out from around the lines enough the lines would pull out. the seals need to be replaced anyway when you remove one of those line.
rktown
10-05-2006 06:25:55
 Re: MF135 lift pump RR in reply to Big Dean, 10-04-2006 14:56:26
Thanks Big Dean. The manual does not mention any rubber seals and I don't remember seeing any with the new pump. Are they standard o-rings or something special from MF?
Big Dean
10-05-2006 08:46:39
 Re: MF135 lift pump RR in reply to rktown, 10-05-2006 06:25:55
They are a special seal about a 1/4" or so long that slide up on the line. If they have not been out in a while they get hard and will not come out of the pump because of the threads and the line will not slide out of the seal because of the flair on the end of the line.
