MF 180 Hydraulics problem question.
Marty G.
10-04-2006 05:00:47
When I removed the hydraulic lift cover, I found a small spring in the bottom of the case not too far from the pump. It`s about an inch long and not too strong. Could someone explain to me where this should be. I was careful to remove the little roller before lifting the cover but I guess not carefull enough to watch for that spring. Thanks in advance for your inputs.
Big Dean
10-04-2006 08:38:06
 Re: MF 180 Hydraulics problem question. in reply to Marty G., 10-04-2006 05:00:47
The linkage in the liftcover has two cams with two small levers going from the vertical lever to the cams one cam is for draft control the other cam is for position control. The spring connects between the small lever and the cam for the position control> Usually when the spring is not on there the small lever will not be in the cam like it should be causing the position lever not to work. I have a picture of this I can email you.
Marty g.
10-04-2006 09:36:01
 Re: MF 180 Hydraulics problem question. in reply to Big Dean, 10-04-2006 08:38:06
Hello Big Dean!
I would really like to see that pictures, cause frankly, I'm not sure exactly what you described.
