exploded bushing
dmerva
10-03-2006 20:00:30
where did it come from? 204 worbull - I drained the oil from the gearbox and at the bottom of the housing below the lift arm piston housing I found a square brass bushing 2+ inches by 2+ inches with an inside shaft opening about 1 7/8 inch, oil holes and slots on either side also pieces of a steel bracket that went to powder.
Aaron Ford
10-05-2006 08:53:24
 Re: exploded bushing in reply to dmerva, 10-03-2006 20:00:30
I rebuilt mine with parts purchased from this site. Your rebuild kit will run about $118 dollars with a reman pump nearly $400. Work carefully and deliberately in a clean eviroment with the proper manual and you should not have any problems. Pumps (in every condition) are also available on ebay. I had the same clearance issue with my oscillator that others have mentioned, but it was easily remedied with a bench grinder. The kit comes with the chambers preassembled, new cam followers, and new pistons. I purchased a new control valve as well. Heck, the guy that sold me the tractor handed me a piece of the piston and the standpipe and said "I hope you are a mechanic!" Good Luck Aaron
Aaron Ford
10-03-2006 22:19:24
Sounds like the cam follower on your hydraulic pump. Look at the hydraulic pump parts and compare. Hope its something cheaper....
dmerva
10-04-2006 09:12:58
 Re: exploded bushing in reply to Aaron Ford, 10-03-2006 22:19:24
well, so much for the three point hitch guess I'll just have to do without it for now. I've got another headache ...er tractor with a tool carrier to use. do you know where I can find a re-man for around 250 - 300? its the earlier mf 240 workbull, i've been told from the 50's
