massey 100 fan belt replacment (diesel).
jerry munzer
10-02-2006 13:50:44
please help!,replacing fan belt on massey ferguson modle 100. how in the heck do you do it.frustrated.
gary in Mt. Dora
01-17-2007 10:29:57
 You're a lifesaver! in reply to jerry munzer, 10-02-2006 13:50:44
It looked to me like I was going to have to remove the entire fron tof the tractor. And since mine is a Frelane Forklift conversion, that was going to be one heck of a job!!!
barnrat
10-02-2006 17:38:35
 Re: massey 100 fan belt replacment (diesel). in reply to jerry munzer, 10-02-2006 13:50:44
Chuck forgot to mention one thing. Make sure that pump shaft is clean before you slide it back into the pump or you could trash the pump seal.
mn.Chuck
10-02-2006 15:06:32
Jerry, Is it a 1100? If so do you have an owners
manual? If not: Loosen the Alternator pivot bolt
and the capscrew on the sltd bracket-push alt in.
Loosen 4 capscrews which secure the the radial
pump shaft to the pulley.After loosened,push drive
shaft fwd until the heads of the capscrews strike
the body of the pump.Rotate the drive shaft until the heads of the capscrews are in alignment with
the receiving holes in the pump cover. Remove old
belt-install new and adj.and realignthe pump drive
shaftwith the crank pulley and tighten the capscrews. Chuck
