TO35 REWIRE project, HELP!
John Mason, Mic
10-02-2006 11:16:29
Hello, I just got this TO35. Been sitting a while. I started tearing into the wiring to check items and clean connections. Question is this. Does the distributor need to be changed if going to 12V? I assume the voltage regulator controls the voltage. Below I explain what was on the tractor when I dragged it home.
The generator is 12V (checks good)missing gearing for tractometer.
The coil is 6V (marked but not checked yet).
I assume the voltage regulator is 6V (see no markings).
The battery that was on it is a 6V.
If I need to simply change the coil and voltage regulator I think I'll convert to 12V as I re-wire.
Please help me and thanks in advance. Sincerely,
RegoR
10-03-2006 06:23:57
 Re: TO35 REWIRE project, HELP! in reply to John Mason, Michigan, 10-02-2006 11:16:29
Hi John,
Lots of this has been discussed in the past; try searching the site (upper right corner on your screen). And for a bit more exposure, try posting the same questions on the Ferguson forum.
Roger
