MF1085 lift arm problem
eriediver
10-01-2006 21:20:11
I just purchased a 1973 MF1085 and the lift arms don't work properly. The draft control lever linkage is connected and operates but there is no effect on the lift arms with the engine running or off. The main lift control lever will operate the lift arms slowly up and down only in the far forward position. In the normal rear position the lever has no effect. When moving the lever from the rear to the front the engine revs up a little,pump no longer dead-headed? Oil levels are good. When engine is off, lift arms hold position until lever is moved to the forward lower point. Can this condition be corrected by adjustments without removing the lift arm cover? Thanks for any help.
