Power Take-off problems TO-35 Ferguson 1957
Ken Harrod
10-01-2006 17:47:19
When drilling postholes and using the power take-off shift lever to engage and un-engage the power take-off the secondary clutch will no longer stop the gears in order to engage the power take- off.
Have to completely turn off the tractor and put the power take-off in gear to engage it.
I have adjusted the clutch pedal free play.
Am I looking at a complete clutch replacement or is there something else that might be the cause.
nboost
10-03-2006 13:55:12
 Re: Power Take-off problems TO-35 Ferguson 1957 in reply to Ken Harrod, 10-01-2006 17:47:19
Big Dean mine is doing the same thing. I will try to adjust them. How many bolts are there to be adjusted. Thanks Shawn
Kenneth Harrod
10-05-2006 15:50:15
 Re: Power Take-off problems TO-35 Ferguson 1957 in reply to nboost, 10-03-2006 13:55:12
There was three on my tractor. I had to adjust both the clutch lever tighter 5/16 and the clutch plate to .045.
Big Dean
10-02-2006 10:32:19
Ken There is an internal pto clutch adjustment that is made up through the inspection hole in the bottom of the transmission bellhousing. I have a picture that shows how to make that adjustment if you will send me an email address I will email it to you.
