135 serial number
s
10-01-2006 09:06:06
Where is the serial number on a 135 ? Thanks
135 fan
10-03-2006 22:18:24
 Re: 135 serial number in reply to s, 10-01-2006 09:06:06
Apparently you can find out the year from the engine serial #. It is stamped above the injection pump on the block. I've had my UK model for over 25 years and have learned more about it on sites like this in the last couple of months than I ever have at a dealer. There is a wealth of knowledge on this forum.
Gerald J.
10-01-2006 09:24:36
Below the dash, about right knee high.
Gerald J.
Stuart brogden
10-01-2006 17:49:07
 Re: 135 serial number in reply to Gerald J., 10-01-2006 09:24:36
Went out to the 135 about knee high on the right side these numbers are cast into what looks like the steering column 5989850 is this the serial number? Looked on the serial number chart on this page and no match , they start with 641000001 am I looking in the right place ? Thanks
Gerald J.
10-01-2006 17:59:23
 Re: 135 serial number in reply to Stuart brogden, 10-01-2006 17:49:07
On my 135 the serial number is on a tag on the lower part of the dash, where its vertical.
Gerald J.
Stuart brogden
10-01-2006 18:33:08
 Re: 135 serial number in reply to Gerald J., 10-01-2006 17:59:23
I'll look again tomorrow when it's light, Thanks Stuart
Stuart brogden
10-02-2006 11:47:24
 Still don't see it in reply to Stuart brogden, 10-01-2006 18:33:08
The serial number page only shows 3 years of production ,is that right?
135 fan
10-03-2006 10:42:44
 Re: Still don't see it in reply to Stuart brogden, 10-02-2006 11:47:24
If you have an older 135 diesel look on the front side on the bottom of the oil pan. It might have the casting date if you are trying to figure out what year it is. 135's were made from 64 to 75 in USA and 641000etc. serial numbers were only used for the first 3 years. Later models started with 9A. In the UK 135's were made from 65 to 79 and had different serial numbers. Also in 1971 they were updated with a few things, most notably a straight front axle.The easiest way to tell the difference is UK models had the 135 emblem near the front of the hood and US at the rear of the hood. They were also made in France but finding info on these ones is difficult.
Stuart brogden
10-03-2006 17:31:56
 Re: Still don't see it in reply to 135 fan, 10-03-2006 10:42:44
Thanks 135 Fan I'll look on the oil pan next time I have some time off.It does not have a serial tag on the lower dash . The 135 emblem is at the rear of hood , making it a US model.
