MF175
Greg in1KY
10-01-2006 05:05:21
MF175 looks to have been taken care of except it looks like it set outside most of the time. 3700 hrs, heavy duty loader with 6' bucket and hay spear-uses internal hydrolics, wheel weights, good to excellent tires, no multi-power, 3 speed trans-hi/low, all guages and tach work except fuel, hood has been replaced with a 180 hood-not sure why, motor seems stought-a little white smoke wile reving(sp?)the motor-a very slight "loping" while idling, lift appears to have not been used much, no leaks to amount to anything. p/s tight compared to most I have been around(don't really know if p/s is called hydrostatic but has the pump on side and hoses to stearing column, with no leaks)lights not working-$5300 delivered with full tank
Good Deal?
