TO35 rewire-neutral safety switch
John Mason, Mic
09-28-2006 08:05:37
Hello, I am preparing to re-wire a 6V TO35. I am not sure if this part that is screwed into the top of the trans housing, right side, toward the front, is the neutral switch. It has 2 connections of some sort. Looks like small wire clips on each. has a rubber boot over it. There is nothing connected there now. If it is the safety switch, is there a way to test it? If it is not the switch, what is it? Where is the switch?
Any other tips on this re-wire? Sure would be nice if we could place pictures in with these questions.
C. T. in Oklahoma
09-28-2006 11:59:05
 Re: TO35 rewire-neutral safety switch in reply to John Mason, Michigan, 09-28-2006 08:05:37
John, you can place pictures with your message, I just never have and don't know how. Check out a "who knows??? and who will tell??" on page five of this forum. Or click this link. C. T.
Link
Dean
09-28-2006 08:33:08
John:
What you describe is indeed a neutral start switch. It should be wired in series with the solenoid start circuit. It will prevent energizing of the solenoid unless the High/Low shifter is in neutral. If good, it should read shorted when in neutral and open when not in neutral. If it doesn't, replacements are readily available at a modest price.
Dean
