mf 135 or mf35
RMO/MN
09-26-2006 17:01:12
I am in the process of looking for a second tractor to do a little of everything and I would appreciate your feed back to a few questions. Thanks in advance. I have decided I want the Perkins diesel, live pto and power steering. I will be installing a front end loader. My questions. 1)What do I need to look for to make sure the diesel engine is in good shape. 2)What specifically should I look at on these two tractors (any problem area's) 3) would one of these tractors be better then the other for removing snow with the loader. 4)What are they each rated at as far as plowing.
Again I appreciate your input
Bob
135 fan
10-05-2006 18:10:11
 Re: mf 135 or mf35 in reply to RMO/MN, 09-26-2006 17:01:12
A 135 will have a direct injection engine that is easier to start in cold weather. It might also have slightly better fuel economy but 3 cyl. perkins are already the most fuel efficent tractors ever made. I own a 135 but worked on a golf course that had 35 with 3 cyl. perkins that was purchased new. If they idle too much or don't get worked hard enough they have lots of smoke which causes some lack of power over time. Power steering is nice but isn't really needed unless you have a loader. 135's also have an improved hydraulic control for the 3 pt. hitch. Both are excellent tractors but a 135 will probably cost a little more. Hope this helps.
135 fan
10-05-2006 18:27:27
 Re: mf 135 or mf35 in reply to 135 fan, 10-05-2006 18:10:11
If you only use the loader occasionally you can get by without power steering. If you use the 3 pt. hydraulics they will be slower in cold weather until they warm up. I have a 7ft. front blade on my 135 that is faster than having to dump the bucket. A 6ft. blade would be easier to push. With a bucket you need at least a 6 ft. to cover the rear tires. If you get a tractor with the swept back front axle, put bushings on both sides of the axle for loader work and check the pivot pin. They only have one bushing from the factory and if it wears out it causes the fan to hit the shroud if one wheel drops in a hole or something. I found this out and thought the whole hood and cowl was twisted. On 135's the draft control is simpler to operate and makes a world of difference when you figure it out. Good luck
135 fan
10-05-2006 18:42:44
 Re: mf 135 or mf35 in reply to 135 fan, 10-05-2006 18:27:27
Just thought of something. Not sure if 35's have constant pumping if you wanted to use the internal hydraulics to operate a loader. Make sure you can get an external hydraulics adapter. If internal hydraulics are used they are slower with weight on the 3 pt. when using the loader. The 3 pt. will also creep down with weight but you could put stay bars on it to hold it up. This would allow for extra weight for traction and take the load off the lift arms so the already slow hydraulics wouldn't be even slower. If you want to keep costs down a good reversable rear blade with stabilizer bars works good.
Gerald J.
09-26-2006 19:16:56
1) See that the diesel starts good with no white or blue smoke while running and minimal black smoke.
2) See that the power steering works. Also the multipower if present. Check the three point lift and load controls.
3) I like the MF-135 better and its more likely to have power steering. You want the deluxe model, not the special. The loader that was on my MF-135 was a bit big and without tire chains it wouldn't move in snow. It wasn't a great snow mover, probably because the loader too too much weight off the rear tires. It was a MF-236 loader. It works fine on my JD-4020 which is probably just about big enough to crunch the MF loader.
4) what plow each will pull depends so much on soil that where one farmer pulls 4 bottoms in sand the same tractor may only pull on bottom in North Texas black gumbo. I pulled 2 16s in central Iowa black dirt plowing alfalfa with my MF-135 at 4 to 5 mph. It had liquid in the tires, but when one of them broke I left them dry. The new tires pulled better dry than the weighted tires did. Must have had to do with the sharp corners on the bars and the full depth of the bars.
It snowed the day before my JD 4020 was delivered. I struggled with the MF-135 and loader all afternoon to clear a path. The 4020 walked over the piles as if they weren't there. Didn't need a path cleared. When I've attacked snow with the 4020 it move it immensly better than the 135.
The 4020 won't go through a 7' tall garage door but it pulled 4 x 18 bottoms though I had a hard time keeping the front wheels near the ground, so I took off a bottom and shifted up two gears.
Gerald J.
