mf135 hydraulics won't fully lift grader blade
mandala ranch
09-26-2006 02:35:35
I recently replaced the pto seal and the fluid and cleaned the hydraulic filter. The three point will pick up my rotary slasher fine but the grader which it used to raise now seems to drag one corner and always lowers to drag the one corner as if the weight is a bit too much. I am not a mechanic but have worked out a few problems lately. Do I need to bleed the system, or is there something else that may need replacing?
Thanks,
Mark
mandala ranch
09-26-2006 19:43:38
 Re: mf135 hydraulics won't fully lift grader blade in reply to mandala ranch, 09-26-2006 02:35:35
Thanks Big Dean, I just parked her up from bush slashing and will run the test in a day or so. I'll let you know how it goes.
Big Dean
09-26-2006 09:35:11
That could be caused my the master control spring letting the draft sensing rod pull out to far and neutralizing the controls there is away to check that by remove the top link and connecting a chain between the implement it will not lift and the rear housing of the tractor. I have a picture that show how to do it here
