Paint Color Exhaust
Larry Counts
09-24-2006 06:54:37
Hello,
I'm trying to find out the original color and type of exhaust for my Fe35.I'm planning on restoring it. It has the 4 cylinder Standard diesel made in Coventry England. The Serial # is SDM-16127. It is currently painted like a MF-135 Red and Grey. Is the exhaust horizontal or verticle.
Thank You
Larry Counts
09-30-2006 09:27:56
 Re: Paint Color Exhaust in reply to Larry Counts, 09-24-2006 06:54:37
Thank you for the quick response. The info you gave me was much appreciated. I�m still confused on a few matters regarding the tractor. It is painted red and grey, with Massey Ferguson 35 decals. It has chrome hood latches on the top of the hood that gives access to the center door on the hood. The FE35�s have no hood latches that are visible in the pictures I have seen, just the access door. The foot rests are of the peddle type not the round rods like I see in pictures of the TE and other FE35�s. The serial tag indicates that it was manufactured in Coventry England.
Once again thanks
Scott in Australia
10-05-2006 17:53:17
 Re: Paint Color Exhaust in reply to Larry Counts, 09-30-2006 09:27:56
Larry,
The hood details and decals suggest an MF - but things get changed by owners at various times.
The problem is the Serial Number - this is definitely an FE Serial Number (the first MF was 74656).
Try scraping a little paint off the engine (it should have gold underneath the current grey).
You could also try Bob in the UK - he posts on this forum from time to time; his email is:
[email protected]
Regards
Scott
Scott in Australia
09-27-2006 17:37:49
Larry,
The Serial Number says that you have an early 1957 Standard Chassis with Standard Motors 23c diesel engine and dual clutch (live PTO).
According to:
Link
and
Link
it should be Grey (tinwork) and Gold (engine, gearbox, transmission, axels.
Good photo at:
Link
However, a search on Google will throw up pictures of FE35s with Red and Grey (they mostly appear to actually be MF35s).
If yours is a UK-built Ferguson (which the serial number suggests) it should be Grey and Gold - if it is a Massey Ferguson it should be Red and Grey.
Regarding the exhaust:
I have an FE35 handbook that shows the exhaust going vertically down from the manifold and turning at right-angles towards the rear of the tractor and running along the underside of the right-hand footplate - ending just beyond the rear axle. Some photos on the 'net show FE35s with vertical exhausts (perhaps these are later modifications).
In terms of colour:
Link
says that for, Detroit-built, 35s the exhaust was the same colour as the engine - although some brochures showed them with aluminium (silver) paint.
Maybe the best thing is to scrape a bit of paint off here and there to see what the original colours were.
Regards
Scott
