MF 180 steering problems
Rudyfd
09-23-2006 14:00:59
I've had this tractor for about 1 year and the steering is about the worst its been. All over the road due to severe drifting and trying to compensate for it. At a stop sign i tried to make a left from a stopped position and almost crashed because it took to long to turn. Checked up front and found no leaks. Can someone help with what might be the problem. Thanks in advance.
jiskies2
09-28-2006 19:23:10
 Re: MF 180 steering problems in reply to Rudyfd, 09-23-2006 14:00:59
Huh! Same thing happened to me a few times. Usually helps when add fluid to the reservior.
jeff
Todd 24
09-25-2006 16:35:13
From your description, the problem could be most anything; but something quick to try would be removing the reservoir fill plug and with the engine running, keep adding fluid as you turn the wheel all the way to one side, then back to the other. Have no idea why this helped tighten mine, but steered much better afterwards. Maybe air in system? Good Luck
