Pony discharging
Stuart brogden
09-22-2006 15:41:32
Working on my second Pony it did not have a generator.I got a generator a new amp guage and new 6 volt battery,wired up like like my first Pony.It is discharging.The amp guage is for the Ford N's but it looks and fits like the orginal Pony guage. My ponies don't have lights so you hook the terminal coming out of the generator to ground right? Many Thanks for any help.
51Pony
09-24-2006 05:42:15
 Re: Pony discharging in reply to Stuart brogden, 09-22-2006 15:41:32
There are four terminals on the old type switch. One comes from the generator, one comes from the ammeter. The switch is self grounding unless the little ground lugs on it's case are loose, or unless you've painted the dashboard it's fitted into, so that might be the trouble. Thre is a terminal for lights, but it you don't have any, there's no wire landed there. I had trouble with the old switch on this one and had to land the terminal at one end of the resistor to ground cause the grounding lug wasn't working. I can send a picture and a digram.
J Schwiebert
09-23-2006 06:02:56
How about a few more details? What are you using for a voltage regulator? Is it just a "cut-out" or is it a regulator? You should have 2 wires comming from the generator. Where do they go? The amp gauge is not your problem unless you have it wired backwards. Do you have avoltmeter? More questions? Also what make and model of generator did you get? I also have a generator troubleshooting chart but I need an e-mail address. More questions? J.
Stuart brogden
09-23-2006 08:34:10
 Re: Pony discharging in reply to J Schwiebert, 09-23-2006 06:02:56
The generator is an Auto-Lite GBM 4804A52C with a cutout relay.The wire from the generator goes to the gen. side of cutout relay.The batt. side of relay goes to a off/on toggle switch then to amp guage then to ignition switch.The off/on toggle is to break the curcuit and keep generator from cooking battery because I don't have a working 3 position light switch .The wire from the terminal on the generator goes to ground,I think this would have orginally went to the 3 position light switch.I don't have a voltmeter.Thanks
J Schwiebert
09-23-2006 19:06:29
 Re: Pony discharging in reply to Stuart brogden, 09-23-2006 08:34:10
I sent you an e-mail. Let me know if you do or do not recive it. J.
Stuart brogden
09-23-2006 20:35:28
 Re: Pony discharging in reply to J Schwiebert, 09-23-2006 19:06:29
Recieved your email.How does the motor test on a generator work ? Thanks , Stuart
J Schwiebert
09-24-2006 06:15:31
 Re: Pony discharging in reply to Stuart brogden, 09-23-2006 20:35:28
You need to send me your e-mail back so I can send the attachment on the troubleshooting chart. J.
John Sugden
10-09-2006 19:30:06
 Re: Pony discharging in reply to J Schwiebert, 09-24-2006 06:15:31
Hi, I too am having trouble with charging system on a Pony, I just got this tractor and it has been sitting for about 15 years if you could email the generator trouble shooting guide to me it would be a great help. Thankyou
