TO-35 - Carburetor Diagram
ScottF
09-22-2006 07:53:41
Does anyone have have an exploded view of a carburetor for a Ferguson TO-35. Mine has a Carter carb on it right now. I bought a repair kit, but would like to find an exploded view of assembly/disassembly.
I am also looking for the same thing for a Marvel Shebler.
Thanks in advance for any help...
Farmer(Ga)
09-22-2006 16:34:52
 Re: TO-35 - Carburetor Diagram in reply to ScottF, 09-22-2006 07:53:41
Scott, Shoot me a email and i'll fw you a carb over haul for a MF,I got it off the 9-2-8n board The carter and Mf are pretty much the same, I have a TO 35 and had the carter carb off last night and saw they were pretty much the same only the carter is smaller,Where did you get your kit? I just need the gasket and neddle and seat. james
Farmer(Ga)
09-22-2006 17:29:07
 Re: TO-35 - Carburetor Diagram in reply to Farmer(Ga), 09-22-2006 16:34:52
Sorry Scott, That was suposed to be MS carb overhaul. James
ScottF
09-23-2006 17:43:51
 Re: TO-35 - Carburetor HELP! in reply to Farmer(Ga), 09-22-2006 17:29:07
I just finished installing the newly repaired Carter carb kit, and now, I have no power. Before I did anything, the tractor wouldn't idle at lower RPMs, and was a chore to start. Now, it fires right up, but putt-putt-putts until I throttle back and let it recover, then it starts sounding better. Then, if I try to put it in 3-HI, it putt-putt-putts again and sputters and nearly dies, until I take it out of gear and throttle back a little to let it recover. It sounds like it is getting too much gas now or something. I had both set screws set at 1.5 turns out. At full throttle, I adjusted the power screw in all the way until it started to die, then backed it off till it sounded the best (about 1-1/4 turns). Soon as I put a load on it (3-HI), it acted the same way? I am puzzled... any help would be appreciated!
Thanks,
ScottF
Jerry/MT
09-24-2006 19:48:19
 Re: TO-35 - Carburetor HELP! in reply to ScottF, 09-23-2006 17:43:51
When you adjust the main jet, screw the power jet adjsuting screw in completely (engine off)but don't jam it down tight, just make contact and then screw it out about 1-1/4 turns. Start it up and let it warm up then accellerate the engine. If it coughs or sputters, try alternately leaning/enriching it by a sixteenth of a turn to see if it improves but don't go below one full turn out.
