slow lift while tractor is moving
don br.
09-21-2006 14:05:55
I have a massey 35 diesel.Lift works fine when tractor is sitting still but when tractor is in gear and moving the lift raises very slowly and sometimes not at all.If I push in the clutch and stop than the lift raises right up.Any suggestions?
Big Dean
09-23-2006 09:33:34
 Re: slow lift while tractor is moving in reply to don br., 09-21-2006 14:05:55
By chance would you be using a rotary mower or a rotatiller when this happen if so check to see if the PTO shaft stops turning when the lift will not raise it if does your PTO clutch is slipping. It is what turns the three point pump.
DavidP, South Wales
09-23-2006 09:43:35
 Re: slow lift while tractor is moving in reply to Big Dean, 09-23-2006 09:33:34
That was going to be the next suggestion.
DavidP
don br.
09-22-2006 18:07:46
Yes, oil is full
DavidP, South Wales
09-22-2006 15:03:29
Hi, silly question perhaps but have you checked the oil level?
