MH 50
Ian Milne
09-20-2006 10:34:18
this tractor has been relialable for years and now is giving me all kinds of grief!
it runs for a short time then the engine starts to sputter and stop, I did a tune-up on it and that didn't work so replaced the distributer cap and roter, no luck so replaced the coil, no luck so had the (Carter) carberetta rebuilt still no luck so took the tractor to the mechanic, he looked it over and ran it for a while and said it was fine, took it home and two times round the field with the mower and it quit again, took the carberetta back to him and he checked it again and said it is fine, fitted it back into the tractor and got once around the field today and it quit! frustrated, can anyone help!!!! what am I missing the gas appeares to be clean
mn.Chuck
09-20-2006 14:27:02
 Re: MH 50 in reply to Ian Milne, 09-20-2006 10:34:18
Ian, Of course it could be a defective new coil,
but when all else fails on these I'm betting that
it is the sed bowl assembly. I have seen this for
many years. They "lime up" and get sediment and
they will flow for awhile and quit. They are hard
to clean-poss an overnite soak in a vat of carb
cleaner but sometimes if it is very old it may be
worth while replacing. Best to you. Chuck
Ian Milne
09-20-2006 19:36:15
 Re: MH 50 in reply to mn.Chuck, 09-20-2006 14:27:02
Thanks Chuck, the bowl is clean and the little brass filter looks fine but I will recheck the flow from the tank
Will Fever
09-20-2006 11:56:57
When it quits does it start up right away, do you have to let it cool down or sit for awhile, how long did the mechanic let it run, full throttle or idling? On auto engines there is an exhaust gas regulator valve, would a tractor have something similar that shuts it down until the tractor cools down?
Ian Milne
09-20-2006 19:29:14
 Re: MH 50 in reply to Will Fever, 09-20-2006 11:56:57
I cleaned the bowl as one of the first things and it had very little sediment in it, the tractor generally starts up after each incident and will run on idle, it generally starts to hesitate when under pressure but not always, it may take as much as 5 minutes and when it sputter it generally stops
justplainjim
09-24-2006 12:19:35
 Re: MH 50 in reply to Ian Milne, 09-20-2006 19:29:14
Ian, my MH50 did exactly the same thing. It would sputter and stop, if you went away for 10 minutes it would restart but would soon sputter and stop again. After much head scratching the problem turned out to be an odd little fuel filter inside the sediment bowl. It's about 3/8 inch diameter and consists of a stack of thin serrated wafers. The wafers were coated with a chalky substance which blocked almost all fuel flow. I very carefully dis-assembled the stack and scraped each wafer clean, then re-assembled. That was the problem. Enough fuel would flow to fill the sediment bowl and carb bowl and allow the engine to start but after a minute or so the engine literally ran out of fuel.
Hope this helps.
Briartown
09-22-2006 20:50:33
Check for a plugged vent hole in the gas cap.
Ian Milne
10-21-2006 17:30:58
 Re: MH 50 in reply to Briartown, 09-22-2006 20:50:33
Thank's for the reply's and yes I have tried all suggestions but have not been able to resolve the problem, my last attempt was to remove and clean the tank and put in new gas, I am at witts end with this tractor, the guy that rebuilt the carberator said I should look for a replacement carb A (marvel schebler) to replace the carter he felt was an inferior carb, any ideas would be much appreciated
