No Clutch on 35
mtnbikerman
09-20-2006 07:16:54
I have a dual clutch 35 with the perkins and have lost all clutch pressure. The thing will go in gear with grinding. I think the problem started with some squeaking then it started grinding when the clutch pedal was pressed down. I looked inside the inspection plate and there were a few large chunks of spun up metal on the plate. I thought the clutches might be worn so I took some of the freeplay out of the pedal. Now when I press in the clutch the engine about stalls and of course the gears grind when I try to put into gear. It still goes in gear but there is no clutch pressure. The disks look to be fine. What should I do?
DavidP, South Wales
09-20-2006 07:38:50
 Re: No Clutch on 35 in reply to mtnbikerman, 09-20-2006 07:16:54
Hi, to start, (with the engine stopped) reach up through the inspection plate hole to the rear side od the clutch unit. If all is well you should feel the three release fingers and the release bearing close to them. Check whether the outer part of the bearing is intact and turning smoothly. I suspect that the bearing may have collapsed.
Please let me know.
DavidP
