MH Pony Starter
massey 44
09-18-2006 15:19:14
In the process of rebuilding my 1949 Pony and it appears the there is a piece missing in the casting where the starter bolts on on the front side of the casting exposing the the starter casting over the drive!! This is on the center casting where it bolts to the engine block!! Is there a piece missing??
Stan(PA)
09-20-2006 05:40:31
 Re: MH Pony Starter in reply to massey 44, 09-18-2006 15:19:14
The starter bolts into the "bellhousing" casting with 3 bolts. It bolts into an area which should form a complete circle. Above the nose of the installed starter should be a flat area that holds the front gas tank support. Looking directly from above, you should not see the starter drive area.
massey 44
09-19-2006 14:40:52
Would if knew how to post them on here
51Pony
09-20-2006 15:18:18
 Re: MH Pony Starter in reply to massey 44, 09-19-2006 14:40:52
Send me an email direct, and I'll send you a picture back.
51Pony
09-19-2006 13:49:12
can you post a picture of what you're looking at?
