MF 165 Diesel Tractor
basic hydraulics system quit working
James Toole
08-06-2000 18:28:08
My 1966 MF 165 Diesel Tractors basic hydraulics sytem quit working. The fluid was quite low, replaced all fluid with MF 1129A fluid, but still no pressure for lifting the 3 point attachment. I understand there may be a check valve or pressure relief valve that could be stuck open. I am going to research, but would appreciate any ideas, where the valves may be, and if necessary where a rebuild kit my be obtained.
Thanks in advance. I hope this message has not breached some rule of the discussion group or life.
TG in VA
08-26-2000 19:51:55
 Re: MF 165 Diesel Tractor - basic hydraulics system quit working in reply to James Toole, 08-06-2000 18:28:08
My 165 has dual remotes. After using a no-till seeder, my basic hydraulics would no longer work.
My tractor has a lever near the gear shift that actuates the remotes. My problem: I did not pull the lever all the way to the rear after I unhooked the remote hydraulics. I thought it was all the way to the rear but it was not. After several days of frustration, I jerked the lever all the way to the rear, the basic hydraulics once again began to work. Maybe your solution is as simple.
Dave
08-08-2000 22:04:52
If your fluid level was low, there maybe some air in the system. If you just work the control lever in all directions a few times you maybe able to work it out. Something to try anyway. A 165 should be a good tractor, there are always bugs to workout.
