Carb adjustment
George Fager
09-16-2006 12:58:05
Any one know how to adjust the carb on a 44 Special?? The one I am working on seams to be running too rich and stalls when going up a hill had the carb rebuilt. Idles good and moves ok but will stall too easly. Thank You
George
Jerry/MT
09-19-2006 09:06:43
 Re: Carb adjustment in reply to George Fager , 09-16-2006 12:58:05
I'm not familiar with your tractor's details but I'll offer you some general advice about what my be causing your problem.
Are you sure its the carb? Check your spark by removing the center high tension lead from the distributor cap, holding it near a good ground, turning on the key and attempting a start. If you have anything other than a fat, bluish spark, your primary ignition circuit has a problem.( wrong point gap, dirty points, bad connectios, bad key switch, etc If you have a fat, bluish spark, bad coil, etc)then check the timing and advance to make sure They are correct. Pull the plugs an see if they are fouled. If they are clean them up and check the gaps. Don't just start changing ignition system parts if you have a weak spark. Do some diagnostics to pinpoint the problem. If you need help, get back to the forum.
Too rich of a mixture leaves a dry, fluffy soot deposit on the plugs. If that's what you find, you can try leaning out the mixture by screwing the power adjusting screw on the carburetor inward. Do it in small increments and check to see the effect by accelerating the engine from idel to part power and noting the engine response. The engine should accelerate smoothly in response to the throttle lever movement.Make a note of the ammount of adjustment you make.
