remotes not working
Connie Lawley
09-11-2006 19:10:12
remotes on MF 275 not working, if you undo the couplins it will shot fluid 6 feet, but will not pick up cutter. what fluid should be used in the MF 275 new to tractors so have no idea what is going on Thanks
Big Dean
09-12-2006 06:19:03
 Re: remotes not working in reply to Connie Lawley, 09-11-2006 19:10:12
The MF275 Trans/Hyd use MF Permatran 3 or one of the universal oils that meets the MF spec sold by most places that sell oil. The auxiliary pump can have a good volume but not have the pressure needed the raise a load. There are a few thing that can cause that. 1. A bad auxiliary pump 2. If you have a two stage clutch the PTO disc slipping when it put under a load. 3. The plug ends not matching on the cutter with the plug ends on the tractor or the ends not plug in good. 4. the cylinder on the cut has a piston seal letting the oil bypass inside the cylinder. Hope this helps some if I can be of further help email me.
