Here's that free tractor
Les
09-11-2006 14:43:47
third party image
Turns out it's a '62 204. Christos, would this have the same engine as the 202?
Used-to-be-Iowa-Dave
09-12-2006 07:15:51
 Re: Here's that free tractor in reply to Les, 09-11-2006 14:43:47
P.S. how did you get it home? It has a front-mount hydraulic pump direct-driven by a shaft coming out of the front of the crank pulley. I'm not sure how you run this with the loader hoses disconnected without running the hydraulic reservoir (loader frame, whichever side the spool valve is on)empty (think it's about 6-8 gallons)and possibly hurting the pump. Can you just cap the hoses? Would think the pump needs to move some fluid to lube and cool. If you give up on this girl, let us know. I could use some parts for my 202. Anybody know where I can get a cab for one of these? Also, my duck's about out of quack.
Les
09-13-2006 03:45:20
 Re: Here's that free tractor in reply to Used-to-be-Iowa-Dave, 09-12-2006 07:15:51
I don't have it home yet. Still working on that. It's about 80 or 90 miles away.
It needs engine work. I'm not even going to try to start it.
09-12-2006 07:05:00
Does the 204 have the shuttle-shift transimission?
Les
09-13-2006 03:44:02
 Re: Here's that free tractor in reply to Used-to-be-Iowa-Dave, 09-12-2006 07:05:00
Yes, it has the shuttle shift. And the owner says it works.
puffie40
09-11-2006 14:58:50
The 202 and the 204 have Continental Z134 gas engines. The 203 and 205 have diesel engines.
In short: Yes, it would have the same engine.
Les
09-11-2006 15:15:22
 Re: Here's that free tractor in reply to puffie40, 09-11-2006 14:58:50
I hope you all note the rare "Rear Mallard" feature. That's to remind you to duck when you get on it.
