Massey 180 hydraulic system
Dave
08-05-2000 19:13:14
Does anyone know if there is a update or retro fit hydraulic pump for a 180. The original pump works ok but it does not put out enough volume to run a front end loader properly. It lifts fine, just so very slow.
Johnny Dyer
08-05-2000 19:54:30
 Re: Massey 180 hydraulic system in reply to Dave, 08-05-2000 19:13:14
Dave,if your tractor is equipped with multipower you may be loosing some pressure at the internal hose between the auxilary pump and multipower pack, you could also hook a pressure gauge to your outlets and check the pressure, I am not sure but 1800-2000 pounds should do it, I had to replace the pump in my 180 last winter, I was only getting about 1000 pounds, the tractor will now almost knock the end gate of my round baler off its hinges. Johnny
