MF 165 steering leak
RichG
08-05-2000 16:11:23
Ok here's the deal, I have fluid coming out from under my steering wheel not alot but enough. What might this be from ( power steering fluid) if so would it be a seal, gasket ????? Any info. would help.
Rich
Richg
08-10-2000 12:22:11
 Re: MF 165 steering leak in reply to RichG, 08-05-2000 16:11:23
Help anyone!!??
Jack in NB
08-12-2000 03:59:32
 Re: Re: MF 165 steering leak in reply to Richg, 08-10-2000 12:22:11
Hi Rich -
My 165 (and parts book) don't have any power steering connections at the box/wheel - it's all up front, so the fluid is not likely ps.
Could it be the oil in the steering box being raised by water getting in?
Try pulling the filler plug to see if it's over-full. If it is, water is strongly suspect, and bad news. There are a lot of expensive components (available only from Massey) in there, and you'll have to clean it out. There is no drain plug I've found; we had to take the side off the box, wash the box out, then replace the gasket with silicone.
Then figure out how the water got in - has to be at the top end under the wheel - and repair that.
Hope this helps.
