MH 33 Hydraulic Pump Overheating
Jake D.
09-05-2006 14:43:28
I have a MH 33 without a 3 point hitch. When the engine runs for more than about 5 minutes, the hydraulic pump gets very hot. I have the pump line going to the back of the tractor with a quick disconnect on it and the other quick disconnect on the return line back to the hydraulic tank. Currently the lines are not connected together. If I hook the 2 lines together to let the hydraulic oil flow throughout the entire hose and make a complete circuit, will the pump and hose from tank to pump remain cool? (I will finish hooking up the control valve and stuff in the future.)I know it isn't a problem with the engine overheating because that's running about 165 degrees F.
JJL
09-05-2006 16:41:36
 Re: MH 33 Hydraulic Pump Overheating in reply to Jake D., 09-05-2006 14:43:28
Yep, you have to hook those two lines together to complete the circuit. Your Massey runs an open circuit so the pump is always running and the fluid needs to flow back to the tank.
Jake D.
09-06-2006 15:23:32
 Re: MH 33 Hydraulic Pump Overheating in reply to JJL, 09-05-2006 16:41:36
Thanks. Today we connected the 2 connections together and the pump didn"t get warmer than it was when we started the tractor.
