MF 85 Rear Axle Drop Down Fill...
Nathan in Ohio
09-04-2006 15:39:13
I am trying to figure out where the fill plug is on my MF 85 drop down axles. I found the drain plug on the bottom as well as a breather about half way up but I have not found anywhere to fill it. Also is the actual axle filled in a different place then the drop downs? Is 80/90 the correct oil for this? Thanks
CharlieShu
09-29-2006 10:26:40
 Re: MF 85 Rear Axle Drop Down Fill... in reply to Nathan in Ohio, 09-04-2006 15:39:13
third party image
My MF85 Diesel manual shows the filler plug on the rear inside of the dropdown. It services both the axle and the dropdown. I am including a picture from the MF85 original manual that shows the dropdown and the filler plug. I use TSC Traveller GL1 spec in my MF85 gas model which I believe is equivalent to 80W90. It seems to work fine.
