MF255 brake adjustments
jiskies
09-04-2006 14:42:40
Hi all. Just wondering if there was an easy way to adjust the brakes on a Massey Ferguson 255 tractor? Adjusted ford 601 easily and was hoping there was an easy way out for the 255...
thanks,
jeff
jiskies
09-11-2006 20:08:59
 Re: MF255 brake adjustments in reply to jiskies, 09-04-2006 14:42:40
finally got around to taking the 15 mins to actually try this...seems to have worked but will have to wait for a bigger slope w/ brush hog to make sure. thanks again
mn.Chuck
09-05-2006 18:48:00
Correct Jeff.
mn.Chuck
09-05-2006 09:29:06
Hi Jeff, The owners manual says: Before adjusting
brake pedals,check and adjust brake pull rod(each
side)length to measurement 20". Adj adjusting nut
against rocker (ahead of axle hsg.)until there is
2 3/4" free travel. adjust other brake to within
1/8 diff in free travel. Easy. Chuck
jiskies
09-05-2006 18:16:55
 Re: MF255 brake adjustments in reply to mn.Chuck, 09-05-2006 09:29:06
that's just on the "brake linkage" adjustment correct? jeff
