135 hydraulics knock when lifted all the way....
pb
09-04-2006 07:57:58
Is this something to be concerned about? It only knocks when they are 100% raised. What's the problem? What's the remedy?
Don-Wi
09-05-2006 11:01:48
 Re: 135 hydraulics knock when lifted all the way.. in reply to pb, 09-04-2006 07:57:58
Like mf poor says, they all do it. I wouldn't leave the lever in like he suggests you can though, I'd drop it down just so it stops knocking. I think it's the releif valve popping, but I don't know for sure. Either way. it'll heat up your oil more than it should be if you leave it all the way up.
There should be a stop on the control on both sides of the lever, one to keep it form going into constant pumping unintentionally, and the other for you depth stop.
BTW- our 285 does it too, so it's not just one series that does it. I'm pretty sure the 35,65 etc... as well as the 100 & 200 sereis all do it, as well as possibly even the newer ones.
Donovan from Wisconsin
MF Poor
09-04-2006 12:02:55
Yours and every other 100 series Massey ever built. When the position control lever is raised to "constant pumping" it"ll knock like that. Lower 3-point slightly and it"ll quiet down somewhat if it bothers you. Nothing to worry about. Mine has done that for 35 years now.
