275 Fuel problem
K. Carlton
09-02-2006 12:04:06
Thanks for responding. I put a new pump on, replaced rubber seals, made a new line for one that leaked. Same results. So I checked the filter housing which one line coming from the pump was cross threaded. This maybe were I am sucking in air. I will replace it and see what happens.
MF#1
09-03-2006 11:48:39
 Re: 275 Fuel problem in reply to K. Carlton, 09-02-2006 12:04:06
Sounds like you might have found your problem. I think I would closely check any other connections just in case. This means that whoever cross-threaded this one "may" have done others. Good luck with it!
