Help! Massey 240 stuck in 4th gear
djw
09-01-2006 15:15:12
Hoping someone can help, I'm about halfway through a pasture regrading job, and my 240 got stuck in 4th gear as I was shifting into reverse. This is a 4 speed with hi/lo. From what I see, it looks like 4th is in the center gate. I have tried rocking it back and fourth with pressure on the gear shift, no luck. I am already running behind and have several jobs booked this fall . I'm hoping I don't have to pull the top cover to fix it, looks like a bear.Any help greatly appreciated. Dave
ric1
09-01-2006 19:20:19
 Re: Help! Massey 240 stuck in 4th gear in reply to djw, 09-01-2006 15:15:12
i have a mf-35 that gets stuck in gear i take off the oil fill cap on top the tranny take a long screwdriver or something like that then you can line up the gears inside. while looking inside study it and you should see how it works RICK
MF#1
09-01-2006 15:52:45
Type in "stuck in gear" or similar in the search window above and carefully read what comes up, especially Big Dean"s advice. Go to his website for more info. Involves a large screwdriver through the trany filler hole.
