Brakes on 178
mf in sydney
08-31-2006 15:22:49
G"day all
The brakes on my 178 do not hold anymore, just wondering how you would go about adjusting them( is there an illustrated text I can view somewhere) or failing that replacing them?
Thanks..... ...mf
mf in sydney
09-01-2006 05:32:27
 Re: Brakes on 178 in reply to mf in sydney, 08-31-2006 15:22:49
I would like to try and tighten mine to see if it helps but how do you go about tighting them?
Regards..... .mf
jogl
09-01-2006 03:57:50
I'm not sure what a 178 is but I'm assuming it is a variation on the 175, of which I have one. My brakes didn't work and I could not tighten them to work either. Well, I could tighten them but they would not grab. So I ordered new brake pads and took it apart. It turned out that the original pads were still good, but the axel casting and the pressure plate had a mirror finish burnished into them. My Dad used to stand on those brake pedals alot.
I took a grinder and ground away the mirror finish (carefully), put in the new pads and the brakes now work great.
The only challange in that job was getting the differential lock pedal shaft out. It had siezed into the casting.
Good Luck,
JP.
