Mf26 hyd:(
phil25
08-30-2006 11:05:09
It's panic mode, prior to total frustration mode:) Here's what i got for trouble; At the raise position, the lift arms will come up as normal but as soon as any weight is applied they stop lifting and hold that position. No strength to lift anything heavier than the hitch arms.
So far the pump has been changed, relief valve replaced, suction filter/o-rings=cleaned/replaced, output filter replaced,main ram seal replaced, operating linkages checked/adjusted with the book, and oil changed.
When it failed i was bush hogging, rough ground/bouncing around and suddenly no more lift power.
If someone can tell me what i am missing/broke it would sure be appreciated, cause i am stumped on this one
thanks
phil25
08-30-2006 11:07:08
 Re: Mf26 hyd:( in reply to phil25, 08-30-2006 11:05:09
Looks like i missed a number make it a MF25hyd:(
