FE35 oil pressure
john
08-02-2000 16:45:10
I have a FE35 with 3cly Perkins. When the tractor is cold it has around 50lbs oil pressure. As tractor is used and warms up the pressure starts to fall to less than 20lbs. At idle speed it has hardly none. I have only had it for a few months, so don't know history of it. I have used it a lot and never had to add any oil. Can someone give me an idea? Main bearing? Oil pump? Thanks for any info.
fergi
08-06-2000 18:16:54
 Re: FE35 oil pressure in reply to john, 08-02-2000 16:45:10
I have the same problem on my 165, just put a new oil pump on it, about a 4 day job on and off. didn't help much. I think mine has worn bearings or under size bearings installed when the engine was redone before i got it. there was enough play in the bearings to feel it when i had the oil pan off. good luck
fergi
