135 leaking from PTO shaft...
pb
08-28-2006 19:00:01
My 135 has a leak in the PTO shaft. I've changed out the PTO seal, as well as the o-ring. There is back and forth play (maybe 1/4 to 1/2 inch) in the PTO shaft itself. When the PTO shaft is pulled all the way out, there is no leak. It only leaks when the shaft is pushed inward. Is this back and forth play in the PTO normal? If it is normal, what am I doing wrong? And, if it's not normal, what can I do to fix it?
Richard in ID
08-29-2006 15:41:16
 Re: 135 leaking from PTO shaft... in reply to pb, 08-28-2006 19:00:01
To get the pto seal to finally hold the oil in where it is supposed to be, I wound up replacing the shaft and carrier bearing. I also replaced the retainer and o-ring as well. Cost over a couple of hundred dollars, but she doesn't leak now. The new shaft does not allow the kind of movement you refer to. The old shaft had a groove worn in it where the seal fit and could not get it to stop leaking, even with a new seal. I just replaced it all and started with new parts. I am no expert, but perhaps the worn carrier bearing is allowing the slack to develop.
