Autolite Plugs
garvas
08-28-2006 10:13:40
Currenty using Autolite 386 in my gas MF35. What is the next hotter range? No one at the auto stores can tell me. One shop said they had a hotter plug but it was in a Champion. Also noticed my distributor cap moving slightly when running. I checked the shaft on the distributor and it did not seem to have any play but something is not right. I think it has always moved a litte. But I don't think this much. Do I need to start looking for a new distributor? As always thanks gang....
rvirgil
08-28-2006 17:30:59
 Re: Autolite Plugs in reply to garvas, 08-28-2006 10:13:40
check the specs on a 388
My local car parts showed a 386 and 388 for my UB Minneapolis. My 44 Massey has 386. Their book said 388 was a hotter plug
rvirgil...Kansas
Jerry/MT
08-28-2006 15:13:08
Your distributor is driven off the cam shaft. Make sure that you don't have a loose timing gear. Regarding the plugs try www.autolite.com and see what the next hotter plug is.
