leaking carburetor
john wilson
08-28-2006 07:07:09
I need some help diagnosing a problem my M35 developed yesterday. Fuel is leaking at a fairly rapid rate from the carburetor, somwhere from the engine side of the unit. I could remove it but I would like to know what I should look out for as the cause of this problem. Thanks in advance.
Jerry/MT
08-28-2006 15:18:31
 Re: leaking carburetor in reply to john wilson, 08-28-2006 07:07:09
Does it leak all the time or just when you shut down and the tractor sits? If it's the latter, you may have a stuck float valve or incorrest float setting. Some times the floats develop a leak and sink in the fuel bowl causing a flooding condition. Try shutting off the tank valve and see if that stops it.
If it's occuring during running it could also be the float valve or the float setting. You'll need to remove the carb to fix it.
john wilson
08-29-2006 07:47:03
 Re: leaking carburetor in reply to Jerry/MT, 08-28-2006 15:18:31
Jerry: thanks so much for this advice - I think it is only doing it when I shut off the tractor. It stopped once I shut off the tank valve. I will get a rebuild kit.
